Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hand Rubbing Clear Coat
Old 11-16-2012, 09:03 PM
jamesrr jamesrr is offline
I just finished putting two coats of ppg clear on my mercury. Then I sanded the whole car with 800 grit wet dry. I then applied a third coat, and I am sanding with 1500 grit. My question is what grit should I use next on my hood louvers and can I hand rub them instead of buffing? I'm sure I would burn the edges if I used a buffer. Thanks, Ron Randolph
