Hand Rubbing Clear Coat
I just finished putting two coats of ppg clear on my mercury. Then I sanded the whole car with 800 grit wet dry. I then applied a third coat, and I am sanding with 1500 grit. My question is what grit should I use next on my hood louvers and can I hand rub them instead of buffing? I'm sure I would burn the edges if I used a buffer. Thanks, Ron Randolph
I did not sand and buff the louvers on the hood of my 34. I made sure the final coat of clear on the louvers was super smooth to avoid having to sand and buff....it worked out great.
Vince |
| All times are GMT -6. The time now is 08:09 PM. |
