Hand vacuum pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2010, 10:47 AM
Hand vacuum pump
Any suggestions on a good vacuum pump? I first bought a solid brass one from HF because it looked to be better built than some others I had seen at 3 times the price, at $18.00 it turned out to be a total POS with the bore being waaaaay too big for the piston. They had packed the darn thing with heavy grease just to make it seal enough to work for a few minutes and a few minutes is all it lasted! Next I bought a "Mityvac" at a local auto parts for about $30 and it lasted a little longer than the HF junk before it too scored the walls of the plastic bore and started leaking around the piston so would not hold what little vacuum it would draw. I then found a "no-name" pump at another auto parts store that was sold specifically for bleeding brakes which I do occasionally, still no luck as the darn thing did the same as the others in a short time-Another $25 wasted. I need a good vacuum pump I can depend on for testing engine sensors/parts, A/C components (individual components not system vacuuming) and occasionally bleeding brakes.
Old 08-15-2010, 09:04 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I've had a MityVac for many years now, use it as often as anyone, I suppose. Never have had the first problem w/it. If there's a "trick or tip" involved, it is to not run anything through it except air. Use a separate reservoir for bleeding, etc. so no fluids are going through it. Should last fine.
I also have a brass 'no-name' vacuum pump, but to be honest, I've not yet had a reason to use it- so can't comment on how well it holds up.
Old 08-16-2010, 04:47 AM
CDJr's Avatar
Experienced Amateur
Last wiki edit: Automobile body and frame rotisserie
Wiki Edits: 2
Same here oldred, I have a little MityVac and have never had any problems with it. Like cobalt said, anything other than air goin through it aint good (even though Ive accidently sucked brake fluid up through mine and it still works fine) Maybe you just got a bad one? Id try returning it for a replacement cuz even though theyre plastic and seem flimsy, theyre actually pretty well-made.
Old 08-16-2010, 03:28 PM
The Mityvac I have has never been connected to fluids so it has been dry. When it first quit working I opened it up and everything inside was covered in a white plastic-like powder, I cleaned it out and everything was ok until I used it again to check an A/C core I was repairing and it did the same thing again. I opened it up again and this time not only was the plastic residue back but the barrel walls are so scored it will not pump full vacuum or hold what it does pump. It has been too long since I bought it (but used it very little) and too far away to return, I might try another one however.
Old 08-17-2010, 02:23 PM
I also have a mityvac, I got the MV8500 kit
http://www.mityvac.com/pages/products_hvpk.asp#MV8500
I have only used it a hand full of times (Brake bleeding mostly) but the last time I used it I wanted to see if a fuel pressure regulator was good so I pulled a vacuum and let it sit for 15 minutes and it was at exactly the same vacuum as I had set it which surprised me since I figured that even if the regulator was good the pump might loose a little vacuum. Maybe you just got a bad one? After doing some research it seemed this was the hand vacuum pump most people recommended so I don't know what to tell you about other options.
Old 08-18-2010, 11:24 AM
If anyone can find a bad one it will be me, I have been doing a bit of searching on the Mityvac and it seems I am somewhat alone in my experience with them so maybe I will just buy another one and try it again.
If they only made two of the darn things defective I probably will buy the other one,
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 08:31 PM
F150 issues ALL FORD Transmission - Rearend 27 06-30-2009 04:28 PM
Converting to EFI 65fish Engine 12 11-10-2007 07:17 AM
87 Suburban fuel pump help needed Mustangsaly Engine 14 10-29-2007 09:04 AM
Which waterpump? Eagle1 Engine 5 08-06-2004 06:38 PM
