hanging pedal conversion problems!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2003, 09:19 AM
Angry hanging pedal conversion problems!!
I have a 1941 studebaker with brake/gas pedal that goes through the floor. I have a camaro front clip built on with front disks. Now I need to put a hanging assembly under the dash and don't know where to start?? Does anyone have some where to turn, so i can finish these brakes.
Old 01-01-2003, 03:23 PM
BOBCRMAN@aol.com's Avatar
Post
how about the swinging pedals from a 60-70's pickup. you will have to brace the firewall, but some of the pickup units are brace and steering column mount all together.
Old 01-02-2003, 07:48 AM
Stinkin_V8's Avatar
Suburbanite Member
Post
Just went through the same thing.. I started with THIS article, but bent my own brake pedal using 2"x3/8" flat steel and an oxy/acet. torch. Turned out to be a lot easier than I expected.
Old 01-02-2003, 09:12 AM
Seon's Avatar
Post
Try this site: http://www.classictruckshop.com/Tilt_Column_Brake.asp
good luck.
