Hansen plasma cutter??
I have a Hansen plasma cutter. Got it from a guy who bought some tools from a bodyshop sell. First of all, I know not a thing on how it works(no paper work). I plugged it in hooked up air(65to70lbs says that on top) attached the ground pulled trigger and no cut.What up? Can someone hook me up with advice or a web site, please? I 've been searching but nothing yet.
Thank you and I'm sorry if this doesn't fit in this section. |
A plasma is somewhat of a complicated critter,, when you plug it in and pull the trigger you should hear air blowing,, it will not work without a supply of air, if the air is blowing and still no arch, then you might check for a relay or reset, still no luck then either its broken or worn out,, plasmas are not cheap to repair,,I bought a snap-on at a auction once that was no good,, the cost to repair it was pretty steep,, but a friend that works at a electrical company had it repaired for free, they had to replace alot of the diodes , it really never did work very well tho,, I bought a HTP 400 and its really a great machine, good luck,, Bill
| Cutting torch ...plasma cutter.....?? | poncho62 | Garage - Tools | 22 | 09-04-2005 08:34 PM |
| I need plasma cutter help | willys36@aol.com | Garage - Tools | 11 | 06-20-2004 08:03 AM |
| Plasma cutter, (correct way) | 39chevy | General Rodding Tech | 7 | 02-27-2004 05:44 PM |
| Which Plasma Cutter should i buy??? | bg | Garage - Tools | 2 | 02-08-2004 04:12 PM |
| plasma cutter died | tm454 | General Rodding Tech | 6 | 11-28-2003 03:14 AM |
