Happy New year/ El Camino 305 to 350 timing marker
Hey Guys I Am Puting A 350 Were The 305 Use To Be. The New Engin Did Not Come With The Timing Marker. Can I Just Use The TIMING CHAIN COVER Off The 305 WITH MARKER THAT IS ATTACHED TO IT. Will The Marks Work The Same As They Did On The Old Sb..on The 350.
HERE is a Wiki page on the differences between the most common damper lines and tabs used on the SBC. DETERMINING TDC will allow you to be sure the timing tab and damper are correctly indicating TDC. Once you have the engine at TDC you can put a new mark on the damper to align w/TDC on the tab you are using. MAKE A TIMING TAPE to see what the total timing is, w/o needing to use a dial back timing light. You can also buy a timing tape, get one that matches the diameter of your damper. |
Timing Marker 0n New 305
THANKS..I WAS LEAD TO BELEAVE THAT THE TIMING COVER OFF THE OLD MOTOR WOULD WORK WITHOUT ANY CHANGES ALSO i AM CHANGING THE DAMPER TO A NEW ONE..SO I WILL HAVE TO THINK ABOUT THE ADVICE. ONE MORE THING. DOES THAT COVER JUST SLIP OFF OR DO YOU NEED TO REMOVE ANYTHING OTHER THEN THE DAMPER AND BOLTS.
| Happy New Year! | adamsautoadvice | Off-Topic | 0 | 12-31-2010 06:44 PM |
| How 2 have a Happy New Year | pepi | Off-Topic | 2 | 01-01-2009 10:21 AM |
| Timing marker off 90 Deg? | BillZ260 | Engine | 4 | 06-16-2008 09:23 AM |
| Happy New Year | JSD Performance | Hotrodders Site Suggestions and Help | 0 | 12-31-2005 09:20 PM |
| No timing marker | GriffTannon | Engine | 3 | 06-10-2004 11:49 AM |
