has anyone used any typed of nozzles with this gun? I looked on there site and they dont have any at all, they dont even specify what size nozzle the gun comes with (anyone know?) If anyone has found any nozzles that will fit please let me know. Someone said the nozzle from the 3408 , i think thats it, the purple HVLP anyway, but someone said the nozzles might be interchangable
The HF guns usually come with a 1.4mm nozzle. I have not seen any other sizes offered. I do know that the HF gun is a knock off of the Sata, but I do not know if the Sata nozzle and needle will fit the HF gun.
hmm i'll have 2 check into it, if i can find some that I can return its worth a shot, I was hoping the nozzles from the other purple HVLP gun My other gravity feed gun has a 2.0mm tip (.082") so I wasn't sure if this one had a 1.4 like most of them do.
**Edit**
I found these tips, would I need the orffice also or do I just need the Nozzle, Sata Nozzles The nozzle on the right looks identical to my 43430 and the sata guns look very similar to it, however the one in the link above in my previous post looks very differnt to my 43430
You need both the orifice and the needle, you may also need the air cap.
Vince
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
