Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - harbor freight bandsaw feed rate
Old 10-28-2004, 06:38 PM
4 Jaw Chuck's Avatar
4 Jaw Chuck 4 Jaw Chuck is offline
Feed rate is determined by the shape of the swarf or "cuttings", you should have nice "curly cues" or figure 9 shaped chips. Tooth pitch is the most important factor when selecting a blade for a bandsaw, you should have three teeth in contact at all times or you risk breaking teeth off, too many teeth in contact raises the pressure needed to effect a cut and also means they will plug up with chips causing increased friction and possibly chip "welding" in the gullet of the tooth.
Here's a good article for reference.
— Han Solo
