Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - harbor freight bandsaw feed rate
Old 10-28-2004, 08:49 PM
cboy's Avatar
cboy cboy is offline
Last journal entry: Finished
Originally posted by willys36@aol.com
Mine has a run-out of about the thickness of the blade @ 5" above the bed.
So at least we know the "run out" in my saw is not common to them all. What you are describing sounds like less than 1/32" in 5" of travel. Mine is more on the order of 1/8" in 4 inches of travel. I just don't think this is a "blade" or "sharpness" issue - particularly when the run out is visible with no workpiece even in the machine.
I just got through emailing H.F. Customer Service to describe the problem. We'll see if they have a solution.
BTW, thanks for the heads up regarding constant lubrication of the blade. Nothing at all in the manual about doing that. I'll have to rig up some sort of drip system.
Always learning...and sharing what I've learned.
