And I have checked each of these tightness settings by placing a square on the bed of the machine and then lifting the head. In each case the roller setting made no difference...the blade showed a run-out of approx 1/8" in a 4" rise of the blade no matter how tight the rollers are set. Which, in theory, makes sense to me. Yes, I can understand that roller (guide block) settings would have an effect on "wander" and "run-out" when the saw is cutting something, but when there is nothing in the machine, the head should rise and fall perpendicular to the bed. And since the blade is in a fixed position in the head, it too should rise and fall at exactly a 90 degree angle to the bed. But mine does not. 4Jaw, I think your suggestion DOES apply to a machine which has a true head (lifts perpendicular to the base) but has poorly set rollers (blocks) and is cutting a workpiece. This could allow the head to drop "true" but the blade would be pushed or pulled out of true by the pressure of the workpiece. However, when there is NO work or workpiece to draw the blade out of true...it would raise and fall at exactly 90 degrees to the bed...assuming the head is a true 90 degrees to the bed. Does my thinking make sense here or am I having one of my usual brain malfunctions? Dewey
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod. |
I set my rollers very tight on the blade and the blade tensioner very tight also. Your problem is a manufacturing defect - they drilled the saw pivot hinge out of square. There isn't anything you can do to fix it.
Well now I'm totally confused...and have to take back some of the prior theory I was spouting off to 4Jaw Chuck. I just went out to the shop and put a square on the HEAD itself, rather than the blade, as I lifted it. And the head itself seems to be running true, or at the most only about 1/32" of run-out. So how could the blade, which is fixed in the head, show more run-out than the head itself?????
I can't imagine how I could get those rollers any tighter to the blade (and still have the saw run) but maybe I'll try that and a lot of lubrication on a test run or two.
Cboy-
I'm up for the challenge ! OK, first, I would take a piece of sacraficial plate, and somehow clamp it to the clamping area. Make a scored cut, but not all the way through. Lift the saw. Take a small plumb bob, and drop the bob from the blade. It should be adjacent to the cut line. It should also be consistant across the length of the blade. WAIT ! Is your cut out of square from top to bottom, or left to right? Is the back fence PERPENDICULAR to the cut line? The "zero" on an adjustable fence is close to worthless until its "tuned". Same goes for ANY chop saw, table saw, radial arm, etc. Once you've established what is out of square, you can add a piece of 3/8" plate to the surface, whether its the bed, or the fence. That plate can be shimmed to square with the blade. Use countersunk screws and thread the cast table/fence. Reboring the pivot bore, or machining the pivot will be alot tougher. |
Guides
Now we are all determined to get Cboy on the square here..GRinnnn
There is no angle scale on the bed of those saws. Angle is adjustable but must be set with some external gauge.
You are right C, your measurements don't make any senses at all! The blade is attached solidly to the head so both should reflect identical run out on the head/bed hinge. Drink a couple of Buds then recheck those measurements! |
"Once you've established what is out of square, you can add a piece of 3/8" plate to the surface, whether its the bed, or the fence. That plate can be shimmed to square with the blade. Use countersunk screws and thread the cast table/fence. " I tried that in a makeshift fashion by simply putting a 1/16" piece of steel on the edge of the bed opposite the saw blade. Then I clamped in a piece of 2x3 stock and cut it. It seemed to be a tad better BUT I think the piece worked itself loose in the clamp and moved up a bit so it didn't give me an accurate reading of just how well it worked. I'll have to try that experiment again. The only problem with laying a piece of flat stock all the way across the bed as you suggest is that the movable end of the clamping device must run up and down a 1" slot that is cut into the bed (the slot splits the bed in a line parallel with the blade). But I think if I could get just a shim piece secured to the side of the bed opposite the blade that I might be able to improve things. Quote:
BTW, just got an email response from Harbor Freight. Useless. They sent me the list of specs for the machine...like motor size, blade length etc.
Before you start Rube Goldberg fixes like that, take it back to HF and get one that is right in the first place.
Yup
I would concur with Willy take it back and get another one..Harbor Frieght stuff has poor quality control..Some of it is good enough but I do run into this sort of thing from those guys..
Spent some time this afternoon fiddling with the saw and got a couple pretty good cuts by putting a 1/32" shim on the bed opposite the blade and then clamping everything very tight and making sure the uncut end of the stock was well supported so it wouldn't force the piece to move during the cut. Oh, and lubricating during the entire cut. I might be able to live with this solution if I can continue to get decent cuts with it.
I'm still trying to get a better response from HF Customer Service. One problem with the return is I had it shipped here (nearest HF store is 5 hours away) and don't know how they handle that in terms of paying for the shipping.
blade guides
Cboy
Cboy Cboy Had to go out yesterday and stopped by HF..If you have the central machinery 4 1/2 in saw the blade guides are attached the the head with 2 bolts ea..the bottom bolt is through a hole and the top bole is in a slot..Now if you were to open up that slot and rotate the guide until the blade is true 90 to the bed then we should be done with this issue.. Course torque it all down good when done.. That spring on the side..all that is is to hold the head up when you are finished with a cut..probably will be necessary to hang a weight on the head to get some down force on the blade.. It does not seem that you are all that much out..just enough to make a guy nutsy.. This type of saw is just pretty good at cutting and I would not find it amiss if I had to touch grind the tubing ends to get the fit I desire.. Take Care
I have tried most all of it and now do what is known to work.. Last edited by OneMoreTime; 10-30-2004 at 08:44 AM. |
Re: blade guides
More importantly, even if one COULD move the guide bracket to one side or the other (by grinding away on the head casting) I don't think it would have any effect on my particular problem. I think we would just succeed in moving the run-out a fraction of an inch to the left of right...but we would still have the same run-out. Even if not, grinding away at these machined in head guides is NOT something I'm inclined to do since I can't imagine HF taking it back in return after I botched up the job. Regarding the spring and handle on the side of the saw the manual identifies it as the "Pressure Adjustment Handle" and says it is used to "Increase or decrease feed pressure." It is not used to hold the head up after making a cut according to the manual.
It was a thought
well..guess you either live with it or send it back..Sorry to hear you have had all this issue with this thing..
OMT,
Thanks for trying to help figure this thing out. Kinda difficult doing it via long distance. It does seem there is no clear adjustment on the head or the blade to remedy the problem. I'm still testing to see if my "shimming the bed" will work as a long term remedy. Meanwhile I'm looking into how I could return the thing without having to make a 10 hour round trip to the store.
Well now THAT'S impressive. I'm out in the shop this afternoon lamenting over exactly what to do about this saw...and up drives my UPS guy with orders to deliver me a new saw and pick up the old one. Well you could have knocked me over with a feather. I hadn't even asked that it be returned yet. Just told HR customer service what the problem was and asked how it might be fixed.
We couldn't actually make the switch today, however, because I had no clue they were sending me a new saw so the old one has to be disassembled and packed back in the box. So UPS is coming back tomorrow. One other little note, the UPS guy said they deal with Harbor Freight a LOT and that they are a great company to work with. Just thought I'd pass that along for what it's worth. Must say I'm very impressed with Harbor Freight on this saw deal, however. Just hope the new one is built right.
| Recent Garage - Tools posts with photos |
