Harbor Freight/eBay Hydraulic Crimper - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-25-2013, 03:44 AM
astroracer's Avatar
Originally Posted by 1971BB427 View Post
If you get terminals sized properly for the gauge wire you're using, you wont have to do the modification to the barrel to get a proper crimp. Be careful not to over crimp and compress the wires strands too much, or it will fracture them and reduce it's load carrying capability.
The terminals ARE the right size, thank you... Overlapping the joint simply makes for a nicer, more consistant crimp. Rather then fighting each other to compress this mod allows the two halfs to slide past each other during the crimping process. Rather then a bulged and buckled mess this creates a nice, even crimp, as you can see...
I didn't see any signs of distress in the crimped joint. You would have to step down on the die size to compress it to much. This isn't going to happen with the correct die size.
Mark
  #17 (permalink)
Old 09-25-2013, 09:02 AM
1971BB427's Avatar
I've never had good quality terminals buckle or get ugly. Maybe the terminals you're buying should be upgraded to a good Stakon or Burndy?
  #18 (permalink)
Old 09-25-2013, 09:47 AM
astroracer's Avatar
Okay, I have gotten more grief for these "crimps" then I like... I thought they were okay for what I am doing but I guess they are not. I will be rethinking the process. I am going to make a couple of new top dies to, hopefully, bring these up to a better standard.
The terminals I have are good quality, it just takes a better process to get a good crimp. I am looking for a "crimp" here... Not a "squash" which is what I have now.
Mark
  #19 (permalink)
Old 09-25-2013, 10:09 AM
1971BB427's Avatar
Sorry Mark. I wasn't trying to give you grief, just trying to help. I've used that style crimper for over 30 yrs. with Panduit, Stakon, or Burndy terminals, and always make beautiful crimps that don't buckle or look bad. But I've occasionally at home bought some inexpensive crimp terminals, and often had bad luck, so I gave up on them.
Again, I apologize if what I said didn't come across the right way.
  #20 (permalink)
Old 09-25-2013, 10:26 AM
astroracer's Avatar
No apologies necessary! Believe me, you aren't the only one telling me the "crimps" are junk... This is why I post a lot of the stuff I do. If it's not right, or there is a better way, I want to know it... Thank you for the input, very much appreciated!
The issue I have with the current dies is they like to squash material out of the sides, between the die halves.This is what I was trying to avoid. I will do some work on a new set of dies for the crimper that will give me good crimps. By rolling the top of the lug down, into the wire Molex style, I will keep it from squashing the metal of the lug out between the dies and, hopefully, give a better crimp. Stay tuned.
Mark
harbor freight cut off saw birkey Garage - Tools 4 01-07-2013 09:46 AM
Harbor Freight eloc431962 Hotrodders' Lounge 27 11-05-2009 11:13 AM
How about this Harbor Freight deal........? PairOf69's Body - Exterior 4 07-27-2007 06:05 AM
20% off at Harbor Freight Tools impalaman63 Garage - Tools 17 07-03-2006 05:32 AM
Harbor Freight guns thj63 Body - Exterior 8 05-13-2004 06:35 AM
