Harbor Freight gas engine - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 02-03-2011, 05:00 PM
You would probably be better off using a torque drive (Northern has them) instead of a centrifugal clutch if you are going to use an engine that big. The clutch would work ok by itself but the torque drive would be much better IMO even with being a bit more complicated. If you decide to use the clutch simply select the one with a bore size to fit the crankshaft diameter of the engine you use then use an axle sprocket and chain of the same tooth pitch, the size of the sprocket will depend on wheel diameter and to a lesser extent the weight of the Kart.
Keep in touch and let us know how it is working out and I am sure someone here will be able to help with any problems you may encounter.
  #62 (permalink)
Old 02-04-2011, 08:22 AM
35WINDOW's Avatar
Last journal entry: Engine!
Originally Posted by matt167
I think Airens builds the JD snow throwers...
I run a John Deere Dealership (Ag and Construction)-we are also an Ariens Dealer. You are partially correct-Ariens USED to build the John Deere SnowBlowers. John Deere exited the SnowBlower business for two Years (in about, oh, 2004 or so). We were so happy with the Ariens Blowers that I took on the Ariens line, and continue to sell/service them over the John Deere (and oh boy, my Deere guy doesn't like me about this). Great Blowers, and I, for one, am glad that the Tecumseh engine is no longer being produced, although most of the problems it had were operator induced .
As for the current John Deere SnowBlower, they are being produced by Briggs and Stratton (which also produces the Deere Generators, Pumps and Pressure Washers)-this is a conundrum for me, as how does a manufacturer of engines compete directly against it's Customers? Anyway, back to your regularly scheduled discussion-
  #63 (permalink)
Old 02-04-2011, 08:42 AM
Wiki Edits: 31
Yep. Cent clutches are really only good to about 5-6 hp even tho most times, there rated to 8hp. They will work, but create extra heat.. torque converter actually provides gearing
  #64 (permalink)
Old 02-04-2011, 09:13 AM
S10Fan's Avatar
Garage Filler
Last journal entry: I need more time!
My Sears push mower used to start the first time every time. With today's gasoline I have to give it 3-4 pulls to get her going. Now I use a Harbor Freight hand pump to snag some gas out of my daily driver for the mower, the mower is back to starting the first time every time.
CA smog questions...engine swaps curtis73 Engine 25 11-28-2012 08:11 PM
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
1968-1969 olds 455 engine is this good and how can i id 1968olds455HO Engine 5 09-02-2009 11:53 AM
Hydrogen Burning Engine, no gas storage... Cyberats Hotrodders' Lounge 101 01-29-2009 07:16 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
