Harbor Freight Line Dyer - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-20-2006, 08:22 AM
gow589's Avatar
the Clever Turn Signal
Any one use this unit specifically?:
http://www.harborfreight.com/cpi/cta...emnumber=40211
Good? Bad?
Old 12-20-2006, 10:18 AM
A friend of mine has a small paint and body shop that uses the HF dryer and he said no problem with it since he bought about year or so ago. Yes, it is made in china, but most window A/C units for houses are also made in China now, including Fedders, GE, Whirlpool etc.
gcrmcc
Old 12-20-2006, 10:43 AM
gow589's Avatar
I do some painting but I also do some sand blasting. The water in the line is killing me. I thought with a filter I would just be replacing filter after filter when I spend all day sand blasting. Therefore I thought a line dryer may be better.
Old 12-20-2006, 10:35 PM
I have a refigerated air drier, but I also use water traps and filters in my lines also. The air drier helps when sanblasting. I don't have the problem with "mud" clogging up nozzle or hose since started using the drier unless it's really humid out.
gcrmcc
Line lock on rear wheel Bandit1980 Suspension - Brakes - Steering 13 03-12-2010 05:53 AM
Anyone ever had a line lock fail and degrade braking? sizemoremk Suspension - Brakes - Steering 7 09-22-2006 02:13 PM
Can 2 line brake system be converted to 4? Neophyte Suspension - Brakes - Steering 8 03-07-2005 08:22 PM
SBC Cooling bypass line question HotRodF100 Engine 2 06-15-2002 06:50 PM
