Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Harbor Freight Pipe Threader?
Old 09-11-2006, 01:59 AM
CDJr's Avatar
CDJr CDJr is offline
Experienced Amateur
Last wiki edit: Automobile body and frame rotisserie
Wiki Edits: 2
If youll measure what all you need, you can most likely buy pre-cut pieces to do the whole job. I have access to a pipe-threader, but I didnt even need to use it when I plumbed mine. Personally, I like galvanized pipe, as its very versatile for adding on or removing, and if you clean the threads and use quality tape, you wont have any leaks. Just my 1 cents worth.
