Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Harbor Freight Pipe Threader?
Old 09-12-2006, 04:11 PM
matt167 matt167 is offline
Wiki Edits: 31
Originally Posted by CDJr
If youll measure what all you need, you can most likely buy pre-cut pieces to do the whole job. I have access to a pipe-threader, but I didnt even need to use it when I plumbed mine. Personally, I like galvanized pipe, as its very versatile for adding on or removing, and if you clean the threads and use quality tape, you wont have any leaks. Just my 1½ cents worth.
that's what I did. a set of NPT dies from 1/8" to 3/4" from HF arn't very expensive and would work just as good
