-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   Harbor Freight Pipe Threader? (http://www.hotrodders.com/forum/harbor-freight-pipe-threader-97790.html)
Kampr 09-10-2006 11:44 AM
I wanted to run copper pipe around my garage for air lines but the more I think about it I don't think it would be worth the extra cost. I'm pretty sure now that I am going to use 3/4" galvanized. Harbor Freight has a pipe threader on sale for $19.99 . Has anybody here used one and if so does it work OK? It would be more convenient to have one while putting up the pipe rather than run back and forth having the pipe threaded. Thanks for any replies.
Danny
OneMoreTime 09-10-2006 11:56 AM
It would certainly be worth the 20 to have that..as long as it lasts well enough to do one job that would be fine..
Sam
22068 09-10-2006 12:01 PM
Made in China? You could always get it and if it doesn't work very well, you could always take it back. Some China junk works well while some doesn't. Guess I'll go over to the HF around the corner and see what you are talking about since I'm going to be doing the same thing soon.
Don Lyon 09-10-2006 01:49 PM
Harbor Freight pipe threader
Hey guy's, keep me in the loop, please. This is my next project,hopefully within the next three weeks. Thanks in advance.
garyroushkolb 09-10-2006 03:46 PM
pipe threader
Why not save the cost of the threader and apply it to the price difference to plumb the air with copper, the time savings alone will make you happier.
I've plumbed both ways and copper is the only way to go. I haven't used pvc but other people here have.
Kampr 09-10-2006 05:54 PM
If the price difference wasn't too great I would really like to go copper. I've sweated in several copper lines and know what I'm doing but I've never threaded pipe. The 3/4" galvanized at Lowes is 12.80 something and the 3/4" copper is 30.80 something for 10 ft. lengths. I may be able to buy the galvanized at a local plumbing store a bit cheaper but I don't think they even carry L copper and I think M copper may be too light. I'll probably need at least 60 ft. to do my job or maybe more. That would be quite a big difference in price and with all of the couplers I'll need would only spread the price out even more.
If nobody else has used the threader and I get one I'll keep you posted on how I like it. I've never used one before so I might not be able to tell if it is a decent one or not. My main concern is getting nice threads that don't leak and have one at my house for convenience.
CDJr 09-11-2006 01:59 AM
If youll measure what all you need, you can most likely buy pre-cut pieces to do the whole job. I have access to a pipe-threader, but I didnt even need to use it when I plumbed mine. Personally, I like galvanized pipe, as its very versatile for adding on or removing, and if you clean the threads and use quality tape, you wont have any leaks. Just my 1 cents worth.
58Chev 09-11-2006 05:10 PM
1 Attachment(s)
I have a cheap threader ($29) from our version of HF (Princess Auto) it worked out well for my air line installation. I figured it would cost me $3 for every threaded end I needed from HomeDepot not including cuting down to size, cost wise it worked out.
Just remember to use plenty of oil, you don't want to make dry cuts. Lots of pressure while making the threads also. My lines work out to be around 60ft also.
The onr thing with PA, even though some of their stuff in made in China. :spank: They have a 100% satisfaction gaurantee, I could use and abuse the itam for as long as I like then return it for full refund. No hastles or questions asked.
Kampr 09-11-2006 05:29 PM
I'll get a chance later on this week to go down there and buy it. Hopefully it'll work out and I'll have it if I ever need it again.
Danny
budynabuick 09-12-2006 06:02 AM
re: Harbor Freight Pipe Threader?
copper pipe (in my experience) does not work well for airline. galvanized is the way to go. the compressor manual should tell you (mine did) how to plumb and what to use (as well as what not to use).that is just my 2cents
keith
matt167 09-12-2006 04:11 PM
that's what I did. a set of NPT dies from 1/8" to 3/4" from HF arn't very expensive and would work just as good
ccb 09-16-2006 08:42 AM
Pipe thread
It is not hard to thread iron pipe, like said above, lots of cutting oil, get a gallon.
Most china machine tools seem to work well, even name brands use china parts. Copper is too expensive and generally not recommended for air pressure it will corrode from inside. Put a few ball valves in line, and lots of "T's" with plugs so you can make new attachments later. You can also plan your runs to use pre-cut lengths and nipples as I have done many times. Use couplings not unions to connect your pipe joints, and a good pipe dope or Teflon tape to seal. Also blow the line out real well before you hook up tools.
Kampr 10-27-2006 08:35 AM
I thought I'd get back and give you my experiences and opinion on the HF pipe threader. I wound up piping my shop connected to the garage and used more pipe than I originally planned. I bought 90' total and had about 4' or 5' left over. I threaded about 40 sets of threads and it wasn't extremely difficult but did take time. I went back and bought my last piect of pipe from a different place and it was made in China. It threaded easier and the threads looked better than the others. A good pipe vise instead of my bench vise would have made things easier. The threads I made weren't as clean as the ones that were on the pipe from the factory but I'm sure they had some very expensive equipment. I had trouble keeping some joints from leaking but I don't think it was the threader's fault because some of them were the factory threaded joints. I'm satisfied with the way things turned out.
If I were to do a project again like this I would go with copper. The extra work and time that it took was not worth it to me.
Danny
