It would certainly be worth the 20 to have that..as long as it lasts well enough to do one job that would be fine..
Sam
Made in China? You could always get it and if it doesn't work very well, you could always take it back. Some China junk works well while some doesn't. Guess I'll go over to the HF around the corner and see what you are talking about since I'm going to be doing the same thing soon.
Harbor Freight pipe threader
Hey guy's, keep me in the loop, please. This is my next project,hopefully within the next three weeks. Thanks in advance.
pipe threader
Why not save the cost of the threader and apply it to the price difference to plumb the air with copper, the time savings alone will make you happier.
I've plumbed both ways and copper is the only way to go. I haven't used pvc but other people here have. |
If nobody else has used the threader and I get one I'll keep you posted on how I like it. I've never used one before so I might not be able to tell if it is a decent one or not. My main concern is getting nice threads that don't leak and have one at my house for convenience. |
If youll measure what all you need, you can most likely buy pre-cut pieces to do the whole job. I have access to a pipe-threader, but I didnt even need to use it when I plumbed mine. Personally, I like galvanized pipe, as its very versatile for adding on or removing, and if you clean the threads and use quality tape, you wont have any leaks. Just my 1½ cents worth.
I have a cheap threader ($29) from our version of HF (Princess Auto) it worked out well for my air line installation. I figured it would cost me $3 for every threaded end I needed from HomeDepot not including cuting down to size, cost wise it worked out.
Just remember to use plenty of oil, you don't want to make dry cuts. Lots of pressure while making the threads also. My lines work out to be around 60ft also. The onr thing with PA, even though some of their stuff in made in China. They have a 100% satisfaction gaurantee, I could use and abuse the itam for as long as I like then return it for full refund. No hastles or questions asked.
re: Harbor Freight Pipe Threader?
copper pipe (in my experience) does not work well for airline. galvanized is the way to go. the compressor manual should tell you (mine did) how to plumb and what to use (as well as what not to use).that is just my 2cents
keith |
Pipe thread
It is not hard to thread iron pipe, like said above, lots of cutting oil, get a gallon.
Most china machine tools seem to work well, even name brands use china parts. Copper is too expensive and generally not recommended for air pressure it will corrode from inside. Put a few ball valves in line, and lots of "T's" with plugs so you can make new attachments later. You can also plan your runs to use pre-cut lengths and nipples as I have done many times. Use couplings not unions to connect your pipe joints, and a good pipe dope or Teflon tape to seal. Also blow the line out real well before you hook up tools. |
I thought I'd get back and give you my experiences and opinion on the HF pipe threader. I wound up piping my shop connected to the garage and used more pipe than I originally planned. I bought 90' total and had about 4' or 5' left over. I threaded about 40 sets of threads and it wasn't extremely difficult but did take time. I went back and bought my last piect of pipe from a different place and it was made in China. It threaded easier and the threads looked better than the others. A good pipe vise instead of my bench vise would have made things easier. The threads I made weren't as clean as the ones that were on the pipe from the factory but I'm sure they had some very expensive equipment. I had trouble keeping some joints from leaking but I don't think it was the threader's fault because some of them were the factory threaded joints. I'm satisfied with the way things turned out.
If I were to do a project again like this I would go with copper. The extra work and time that it took was not worth it to me. Danny |
| Recent Garage - Tools posts with photos |
| Exhaust Diameter Formula | ChevelleSS_LS6 | Engine | 11 | 04-27-2012 09:21 PM |
| air lines | CARGUY | Garage - Tools | 96 | 11-16-2006 04:11 PM |
| Pipe Bender Question | silm man | General Rodding Tech | 17 | 11-21-2004 04:30 PM |
| Airlines | Kevin45 | Garage - Tools | 22 | 03-04-2004 04:35 AM |
| Is 2 1/2 pipes big enough? | Mustang_Killa66 | Engine | 7 | 02-12-2004 08:04 AM |
