Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hard to find 41 & 15 tooth speedo gears 700r4
Old 09-11-2012, 11:21 AM
SSedan64's Avatar
SSedan64 SSedan64 is offline
GM #1362195 41-tooth Yellow
GM #8642620 15-tooth Gray
Type those #'s + your Zip in here >> Welcome to the part locator
Several Stores show the Driven gear is available, only 2 show the Drive gear.
If you can't find exactly what you need, a Ratio Adapter may work, PATC has them.
Good luck, Todd
