Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hard to find 41 & 15 tooth speedo gears 700r4
Old 09-12-2012, 06:22 AM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
the after market grey 15 tooth gears are tight on the output shaft. Be careful, it is best to lightly sand the ID on the gear so it is not so tight. We had one gear split open as it was pushed on.
I have a new Delco yellow 41 tooth gear, in the box. Yep , they are pricey
