Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - hard hot start, white smoke smells like gas
Old 09-11-2012, 07:19 PM
RWENUTS's Avatar
RWENUTS RWENUTS is offline
Please note:
All quadrajets use a spring. Actually a bi-metal coil. Whether in a choke stove attached to the intake or in a housing attached to the carb in a hot-air choke or an electric style that uses 12 volts to heat the coil.
And none will close slowly when it's hot until you step on the gas pedal and release the choke lock out.
Tag!! You're it!!
