Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - hard hot start, white smoke smells like gas
  #21 (permalink)
Old 09-12-2012, 10:24 PM
gsoleski gsoleski is offline
Originally Posted by RWENUTS View Post
You might need to pull it apart to check the float and needle/seat.
First try the look see in while running (use a small flashlight to see better). If you see fuel then tap near the inlet with the end of a big screwdriver. Sometimes that will dislodge any junk in the needle/seat.
Or while running pinch off your fuel hose with some pliers, hold it about 10 seconds then let it go. That might flush it out.
Ken's QuadraJet
Thanks i'll give this a try first. Am I looking for fuel pooling in he carb or something? I'm a little nervous about taking it apart, I couldn't even tell you what the needle and seat are for. And what could be stuck in there that could sneak past the filter? Just stuff in the gas?
