The Qjet in the photo does not have the spring behind choke pull off diaphram housing, Other Q jet does have it.
Like I wrote before not all Qjet use the spring. |
A hot fuel pump won't be a problem.
Originally you said you saw a wisp of vapour coming out by the choke plate. That indicates a high float due to something stuck in the needle/seat or possibly too much fuel pressure. After you warm up the motor leave it running and look into the carb below the choke plate. You might see a little raw fuel in there. And you might hear a slight crackle inside too. It doesn't take much flow to cause it to flood. You might need to pull it apart to check the float and needle/seat. First try the look see in while running (use a small flashlight to see better). If you see fuel then tap near the inlet with the end of a big screwdriver. Sometimes that will dislodge any junk in the needle/seat. Or while running pinch off your fuel hose with some pliers, hold it about 10 seconds then let it go. That might flush it out. Here's a link to a quad rebuild with pics. The carb there is similiar to yours except for the other pull off pot on the front. Ken's QuadraJet |
Here's a pic of a choke pull off with the spring lg1969 is talking about. Your carb doesn't have this style.
Just an FYI for you. Choke Pull-Off fits 1973 Chevy - Rochester Quadrajet Carburetor Parts |
Yup! You might see a little fuel dripping inside. If you don't see some have someone shut the motor off for you while you look inside. If a little mist of vapour appears then you know it's flooding a bit.
Try the hose squeeze or tapping by the inlet too. The needle/seat is what controls the amount of fuel going into the carb bowl. It sometimes doesn't take much of a piece of junk to keep the fuel from getting past the needle. Look on that last link I gave you. You'll see the needle/seat in a pic in there. |
First the, the photo shows the choke straight up when it's warm so that can't be the problem. These things were notorious for having internal leaks at the base of the well where the jets and rods reside. This well has 2 lead plugs in the bottom that leak in more than half of all the quadrajets I've ever seen. Lots of the rebuilders don't have any way of checking this. They just replace the carb if they leak. Some kits come with a chunk of rubber that fits between the rod and jet well bottom and the carb base. I would first, try to get the seller to exchange the carb. If that fails, remove the screws in the bottom of the carb and carefully seperate the body and the base while leaving the carb linkage in place so you won't have to figure how it goes if you take it apart. install a rubber plug available at the auto parts store in the open space in the center of the carb and bolt the carb back together and try it. If it doesn't work, you'll have to take it apart and learn about a very complicated carb. One more tip: take it apart on a bench after first draining the bowls by turning it upside down. Then on a work bench covered by a soft towel to prevent the check balls from bouncing across the floor, take it apart. |
Quadrajet carb rebuild
Here is a company you can send your carburetor to have rebuilt. Check them out. SMI Carburetor Other Services Rebuilding & Modifying Rochester Quadrajet Stage 1 Quadrajet Modifications SMI- Sean Murphy Induction
| hard to start, gas smell, little power | CanOkie | Engine | 9 | 02-06-2012 12:32 AM |
| White smoke at start up. | Rodillac | Engine | 6 | 08-11-2010 06:34 PM |
| Easy cold start, hard hot start | dedub | Engine | 34 | 08-13-2008 05:21 PM |
| gas smell hard start | camaro guy | Engine | 1 | 04-06-2007 05:28 AM |
