hard hot start, white smoke smells like gas
After you turn off the ignition. Check the carburetor to see if gas is dripping inside. Sounds like time for a rebuild.
Your Qjet has a spring that pushes the choke closed even if the car is warm as soon you shut the motor.
It sit right in front the choke diaphram. Remove it. It's causing the carb to flood. |
Choke is open in the morning till you step on the gas. Then it closes and sets the choke high idle in to place. When you fire up the motor the choke pull off opens the choke blade about 1/4 inch. As it warms up the choke blade slowly opens and when you tap the gas the choke drops out of place and your motor idles at it's normal setting.
A choke that stays partially closed doesn't make it flood. It makes it run exremely rich. Something stuck in the needle/seat makes it flood. Or a sunk float makes it flood. Like cdminter said. Could be rebuild time or take it apart to see what's in the needle/seat. Here's a link on quads. Explains everything in there. Quadrajet Info by Lars - Corvette Forum : DigitalCorvettes.com Corvette Forums |
I did not mention the spring that control the choke with temperature. There is a tiny coil like spring that the minute you shut the engine it shut the choke closed right away. Even if the motor is very hot.
If the motor is very hot and the choke is set right then the choke won't even move. If the choke is adjusted too rich it will close a bit and might even set up on the high idle.
One note: Not all Qjets use the spring. The one that the choke stays open after you shut a hot engine does not have the spring. That is way it suppose to work. As it cools slowly the choke flap will close slowly.
Please note:
All quadrajets use a spring. Actually a bi-metal coil. Whether in a choke stove attached to the intake or in a housing attached to the carb in a hot-air choke or an electric style that uses 12 volts to heat the coil. And none will close slowly when it's hot until you step on the gas pedal and release the choke lock out. Tag!! You're it!! |
Please 'splain further. |
Sorry for the confusion, It's not the bi-metal I'm writing about. A while back I bought a new Q jet for a 350 69 Caprice. The minute I shut the car off and try to start it later, it would shudder and smoke at tail pipe and smell of gas. It started fine when it was cold. It had that little coil spring . I grab a needle nose and removed it. My old Q jet did not have that spring so the choke would stay open when the motor was hot. It would start up right away. A friend cross the street had the same thing his Chevy 2 barrel dual jet, and could not start it once it was hot. He also removed the spring when I told him. After that it started with no problem.
Thanks!
I don't know why it would do that. I'll ponder it a bit. Only reason I was in clarify mode was I was concerned we might confuse the OP too much. My apoligies to the OP for jackin' his thread and apoligies to you lg for the rant. |
| hard to start, gas smell, little power | CanOkie | Engine | 9 | 02-06-2012 12:32 AM |
| White smoke at start up. | Rodillac | Engine | 6 | 08-11-2010 06:34 PM |
| Easy cold start, hard hot start | dedub | Engine | 34 | 08-13-2008 05:21 PM |
| gas smell hard start | camaro guy | Engine | 1 | 04-06-2007 05:28 AM |
