Hi,
No power assist - Bad Booster Rich |
not always the case.. I had a '92 Ford ranger that, would blow out the check valves at the booster, and often times would leave the hose connected enough to not effect the idle, but not enough vac to operate the brakes.. then one day the valve wasn't busted so I figured the booster was.. when I went to get numbers off the booster for the junkyard, I found the vac line split wide open underneath..
stuck wheel cylinders and or calipers will give ya a no give pedal.
Is the bore of the new master cylinder the same as the original? If it is larger, it will give you a harder pedal.
Andy |
| rock hard brake pedal | Deezildennis | Suspension - Brakes - Steering | 9 | 04-11-2010 03:30 PM |
| Hard pedal | anyoldchevy | Suspension - Brakes - Steering | 6 | 06-01-2007 09:34 PM |
| Hard pedal- little brake power | crash | Suspension - Brakes - Steering | 18 | 01-15-2007 06:33 PM |
| Rock Hard Brake Pedal | 64nova | Suspension - Brakes - Steering | 9 | 11-16-2006 03:34 PM |
| possible hard pedal | blackbeard | Suspension - Brakes - Steering | 16 | 01-10-2005 06:23 AM |
