Something is amiss here. There's enough vacuum, so I'd be looking at the pedal ratio, the MC bore to the caliper bore as well as the combination valve if used.
Another possibility is if the MC is bottoming out, it may be internally bypassing fluid around the seal(s). Can you see what the line pressure to the front brakes is? The MC was bench bled, right? |
Anyone ever try this ? 454 RATTLER |
have you looked to make sure there are 2 different size chambers on the master cylinder ? i think you are bottomed out .
| 68 mustang hard brake pedal | rick3658 | Suspension - Brakes - Steering | 8 | 07-09-2011 03:50 PM |
| Power Brakes have hard pedal ! | wretched ratchet | Suspension - Brakes - Steering | 15 | 01-04-2011 05:48 AM |
| hard pedal | wayneooo | Suspension - Brakes - Steering | 5 | 12-22-2010 07:37 PM |
| Hard pedal | anyoldchevy | Suspension - Brakes - Steering | 6 | 06-01-2007 09:34 PM |
| possible hard pedal | blackbeard | Suspension - Brakes - Steering | 16 | 01-10-2005 06:23 AM |
