Hard shift after kickdown cable replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2012, 07:20 PM
Hey Guys!
I just changed my kickdown cable in my 93 TA with a 700r4. I'm not a certified mechanic but I try to do most of my own work. The cable was installed and then set-up/adjusted. Now I'm having hard shifts that aren't shifting until 3000 - 3200rpm. If I take her out on the highway and stand on it, it kicks into passing gear and goes like a raped date... It was shifting hard when it was leaking fluid when the cable melted but if I topped it up to get it home or out to the shop it shifted fine untill it leaked more and then would shift hard again. There's not a drop coming out and there's 5-6 liters of fluid in it now but it's shifting late and I'm totally fresh out of ideas.
Any help would be appreciated!
Thanks guys!
Chris
Old 10-17-2012, 04:49 AM
SSedan64's Avatar
Hard/Firm/Late shifts will occur if the TV cable is adjusted too tight. Many Aftermarket TV cables are slightly short or long & cause the factory setup method to be off. Try loosening the TV cable a click or 2 & retest.
TV 101, 3-parts > Bowtie Overdrives | TV Made EZ
http://news.compperformance.com/Inst...ble_adjust.pdf
http://www.jakesperformance.com/TV_C...etup_Info.html
700R4 Info Page 1
700r4, hard shift, kickdown replacement, late shift
200 4r TV cable - no WOT, hard 1-2, no kickdown 60smotorhead Transmission - Rearend 27 07-28-2009 05:24 AM
kickdown cable yragat Transmission - Rearend 17 03-21-2008 03:44 PM
kickdown cable glendale001 Hotrodders Site Suggestions and Help 1 11-07-2006 06:00 PM
kickdown cable underdog305 Engine 1 01-06-2005 08:05 PM
Kickdown cable help! Slant3 Transmission - Rearend 4 05-31-2004 07:05 PM
