Hard shifting - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2003, 02:44 PM
Post Hard shifting
Second day driving my truck under these conditions....
first day: shifter wouldn't stay in third gear.
today: after driving on the interstate my truck wouldn't go into 1st, 2nd, or 3rd.
Any ideas?
No noises or grinding, just hard to put into these gears.
Old 04-19-2003, 07:34 PM
Post
I would check a few things. Take the fill plug out of the side of the transmission and see if you have the proper amount of gear lube inside the transmission. It should be filled right up to the inspection hole, when the car is parked on a level surface.
Second, check to see if the shift linkage is adjusted correctly. The shift arms on the back of the transmission are usually designed to line up so you can run a 1/4 inch rod thru all of them, when the shifter is in neutral. If this is not the case re-adjust the shift linkage. Check to be sure the shifter is mounted tight to the transmission.
Check the hole in the floor board that the main shifter arm goes thru to be sure there are no obstructions.
Lubricate the pivit points of the shift rods and shift leavers on the transmission.
Check to see that your throw out bearing (clutch pedal)is adjusted properly. You should feel a little play in the clutch pedal before it makes contact which means your throwout bearing would be about 1/4 inch behind the fingers of the presure plate when the clutch pedal is all the way back. Check to see that your clutch pedal is coming all the way back.
Old 04-20-2003, 05:11 AM
Post
I would go with the fluid first. I actually had that problem on one of my camaros, luckly it would go into reverse and I was about 2 miles from home. I ended up driving the 2 miles in reverse with a school bus facing me. Funny thing is I actually think I was doing 30 in reverse. Filled it up and every gear worked, found out later I had a leak in the case.
Old 04-21-2003, 03:47 AM
Post
I drove it again yesterday, I was able to drive in 1st, reverse, and forth gear. No 2nd or 3rd. If I place shifter in 2nd or 3rd, shifter stays there , but the gear doesn't grab, just a slight chatter. I found that strange, seems like it would be 1st and 2nd, or 3rd and 4th, not 2nd and 3rd?
Old 04-21-2003, 03:59 PM
adtkart@aol.com
Post
I hate guessing on something like this, since I don't know what transmission/shift linkage you have, but here goes. On some standard transmissions, although usually the ones with the shifter inside, the shift forks get worn out. Actually with the internal shifter type it is actually the inserts on the forks that wears out. What happens is that people keep pressure on the shifter while driving. The shift fork is forced against the slider, causing the fork/insert to wear. The transmission then can't go all the way into that gear. I have seen them worn out going into any of the gears, although it is usually the 2nd gear or 4th gear that has the problem as it is the position towards the driver. That may be what the noise is that you are hearing. Since the shifter is going all the way to that gear and the slider isn't. Something to think about. Good Luck
Old 04-26-2003, 05:14 AM
Post
well, I pulled the tranny in an attempt to replace with a friends old tranny...nothing but trouble! the tranny doesn't work very well.
I was so frustrated that I sat and thought about my old tranny, pulled off the side cover and saw that one of the shift forks look different then the other, was just wondering if the shift forks are differen on a saginaw?
One fork is shaped like a "C" the other is shorter.
