Hard shifting/clutch adjustment - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2005, 10:47 AM
ViperMonster800's Avatar
Caprice/Camaro/BMW
I have an 83' Nissan 720 4WD 2.4L 4-cyl. pickup.
I have a 5-speed and hard shifting. When I shift from pretty much any gear, it takes some force to put it in gear. I noticed my clutch has a bit more freeplay than what its supposed to have, says my repair manual. I have two questions for this...
1.) Can this be my problem to hard shifing?
and
2.) Does anyone have any easy tips to getting at the adjustment nut on my clutch pedal? It's in a pretty tight spot against the floor/wall.
~Glen
Old 03-08-2005, 04:41 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
The first thing I think of when a manual transmission becomes hard to shift, is synchronizers.
I will however agree that if you have too much clutch pedal play, you may have a problem getting into AND out of every gear.
Which will eventually take out the synchro's.
I would think the clutch adjustments would be more toward the bellhousing side of all the linkage that connects your pedal to the clutch fork. Hydraulic clutch systems are less complicated with their fewer parts, but there is still some amount of adjustment involved in both types of systems.
Hard lessons being learned here... please help Cracker Red Body - Exterior 2 12-31-2004 06:21 PM
Stall wrong, transmission shift adjustment, suggestions? frankenvette Transmission - Rearend 3 10-26-2004 12:59 PM
Hard to find F.A.Q. Charles F. Smith Engine 0 06-02-2004 04:23 PM
my tranny wont shift hard even with shift kit notmrgoodwrench Transmission - Rearend 4 08-12-2003 07:10 PM
1970 ford 302 valve adjustment coolBreeze Engine 2 08-20-2002 04:32 AM
