hard start - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2013, 07:47 PM
hard start
hi i have two issues recently i changed my intake bolts and some coolant leaked into oil can i assume the leak is resealed with retorque? there is some foam in the valve covers but not sure if its still leaking or if that was it .would a system pressure test be the best confirmation ? next, moved my battery to trunk used welding cable for pos. and negative starts fine cold but barely turns over when hot unless i hook up second battery at engine .ground is good could these two issues be connected could coolant be getting into cyl causing hydraulicing ?
Old 03-25-2013, 08:34 PM
Did you put a little sealant on the threads. if so you'll know you're fine , if not maybe or maybe not. What size welding cable? I would use a min. of 2 gauge cable. If you have good cable and connections I'd would suspect yhe starter soleniod if it's a gm. If t's a gm you might try installing a jumper wire from the start terminal to the B+ terminal and installing a ford soleniod in the battery cable.
The Following User Says Thank You to tresi For This Useful Post:
stmontecarlo (03-26-2013)
Old 03-26-2013, 12:14 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Many of the intake bolts go into the water jackets and will leak if you don't put a sealer on them when you install them. I use Permatex but you can use a silicon based sealer or pipe thread sealer. The hard starting when hot is a timing issue. Set the timing correctly and that problem will likely disappear.
The Following User Says Thank You to S10 Racer For This Useful Post:
Old 03-27-2013, 08:05 AM
Richiehd's Avatar
JS-70
Make sure mechanical advance is working properly and not froze up.
Old 03-27-2013, 08:29 AM
RWENUTS's Avatar
When you changed the intake bolts did you do them one at a time?
If not you might need to replace the intake gaskets.
I ran a battery in the trunk of my 56. Had starting problems too until I ran a seperate ground cable from the battery back to the motor. Didn't seem to have a good ground thru the frame connections.
Old 03-27-2013, 11:21 PM
S10 Racer's Avatar
X2, you can't seem to have too many grounds.
hard to start bigunk Hotrodding Basics 4 11-15-2011 06:47 AM
Easy cold start, hard hot start dedub Engine 34 08-13-2008 05:21 PM
hard to start MARK TINNELLY Engine 7 01-13-2006 12:12 PM
Hard Start fred56 Electrical 5 09-15-2005 07:05 PM
hard start D351W Engine 4 01-04-2005 03:50 PM
