hard to start - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2006, 08:50 AM
MARK TINNELLY's Avatar
87 AEROCOUPE
hard to start
i have a 400 sbc in my 87 montecarlo.
sometimes when the engine is warm (after heavier than usual driving) the car is hard to start, it will crank over VERY slowly about four to five times and then start no problem.
I have changed the battery, the starter, added two more #6 ground wires,
changed the altenator and the belt, the headers are ceramic so there is very little heat going to the starter but I installed a heat shield anyway, i even went as far to get a new chip for the computer from jetchips as i thought it was the timing, but still it is hard to start, can anybody help me, it has never let me down but i know it is only a matter of time!!!
Old 01-13-2006, 09:03 AM
engineczar's Avatar
What you might want to check are the springs and weights in the distributor and how freely they return when the engine is shut down. The whole thing sounds like too much timing while the engine is cranking.
Old 01-13-2006, 09:07 AM
87 AEROCOUPE
you are a smart man
this is why i come to hodrodders.com,
thank you sir
Old 01-13-2006, 09:09 AM
MI2600's Avatar
Member# 3287
When you say that you changed the starter, was that a new starter or just another that you had? I had a similar problem and swapped out the starter for another I had. The problem continued. It wasn't until I put in a new/remanufactured starter that I resolved the problem.
Old 01-13-2006, 09:12 AM
87 AEROCOUPE
no brand new
no, the starter is brand new, in fact both of them where, cause when i changed the motor the original starter would not fit from the 305 to the 406
Old 01-13-2006, 10:27 AM
wildfire78's Avatar
wildfire78
I have to agree with engineczar, it sounds like to much advanced timing. If you have a vacuum advance it could be sticking also.
Old 01-13-2006, 11:56 AM
hard starting
Have your starting system load tested most auto parts store will do this,it is possible that it is a timing advance problem but i doubt it?
Old 01-13-2006, 01:12 PM
The starter system should be checked for voltage drop.
intermittent hard start 71-longbed Engine 10 01-13-2006 08:21 PM
hard start when hot blazin47 Engine 9 09-26-2005 09:08 AM
Won't Start fasano89 Engine 4 11-28-2004 12:57 PM
Hard to start when damp outside Vista Cruiser Electrical 5 05-16-2004 11:18 AM
Car Hard to start?? HotRodMan Engine 7 03-12-2004 11:26 PM
