Hard to start once hot. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2008, 12:21 PM
Here is a quick idea of what i got;
408w, aluminum heads, 8-71 BDS blower, soild cam, mallory ignition box distributor and coil. Carbs are Holley 750's with Vac secondaries.
Problem:
The car fires up pretty quickly whne its cold, but once it gets up to operating temps (180-200) and you shut if off, it is ver difficult to start. I have found it will start up if you hold the pedal down and crank of for 20 sec straight, but i really dont like doing that. So far I have checked the floats, there good. Timming is right on, and no bad grounds that I can find.
What else can I check for?
Old 04-30-2008, 12:32 PM
Jmark's Avatar
Having to hold the pedal down to start it, leads me to think it's flooding some after shut down. Next time you shut it down hot, look down the carbs and see if you see any gas dripping anywhere. You could have a little too much fuel pressure or a needle and seat that is not doing it's job. You can also try lowering the floats to about 1/16" inch below the site hole. Might help.
Old 04-30-2008, 12:36 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
Sounds to me like you have a carb that is draining down and flooding the engine. Get it hot and shut it off, crank it some and pull all of the plugs and see if they are wet. My blower motor starts rihjt up when it is hot, don't even have to touch the pedal. Holding the throttle open indicates to me that the engine is flooded. You need to find the problem quick, it will wash out the cyl walls and ruin the rings. Could also cause the engine to backfire and warp the rotors in the blower.
dawg's Avatar
NAVY VETERAN
I had same problem years ago and ended up being the coil.
Old 04-30-2008, 04:08 PM
Okay, I'll take a look at the carbs this weekend. I pulled all the guagues out to redo the dash bezel at the moment.
Thanks for the advice!
Old 04-30-2008, 08:01 PM
Big Don's Avatar
Hot start
Carb leak down when hot- it sounds like. Next comes fuel Hyd lock,,,,,very bad condition. Fix it soon.
Hard to start when hot oldred Engine 3 05-09-2007 09:32 PM
intermittent hard start 71-longbed Engine 10 01-13-2006 07:21 PM
Hot Start Issues SB 350 subman17 Engine 4 11-10-2004 11:00 PM
Chevy hot start problems narrowed down mark2002 Engine 7 07-03-2003 06:06 PM
350 hot start 74huggerorange Engine 9 03-04-2003 08:52 PM
