Hard Starting - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2011, 02:05 PM
hoops's Avatar
Hard Starting
I just recently built a 350. Whereas I've done engine rebuilds before, they've always been stock engines. However, this new rebuild is beefed up some. I'm running about 9:1 compression because of the stock bore, the 70 cc heads and the flat top pistons. The engine has the following:
1) Edelbrock Performer RPM Heads
2) Edelbrock Performer RPM Intake Manifold
3) Comp Cam (see picture of card)
4) 1 5/8" Headers
5) Mallory Unilite Distributor w/ Mallory High Output Coil
6) Edelbrock 750 CFM Carburetor
7) Miscellaneous other minor stuff including 1.6 Rocker Arms
The engine starts great when it's cool, but when it's at normal operating temperature it is sometimes hard to start and when I say hard to start I mean it takes about two or three seconds of cranking.
The Mallory Ignition has the original timing curve it came with and right now I have 12 degrees of initial advance and the distributor has 24 degrees of mechanical advance.
I plan on changing the distributor mechanical advance to 18 degrees (all in at approx 2600 RPM) and the initial advance to 18 degrees for a starting point. Do you guys think this will help the hard starting when the car is hot?
Here is a link to the image of the cam card just incase I didn't upload it correctly:
http://www.hotrodders.com/forum/atta...id=55372&stc=1
Thanks in advance.
Name:	Cam Specs.jpg
Old 05-16-2011, 02:42 PM
UngerMarkus's Avatar
TuckīnīRoller
since you say that the problem only occurs when the engine is hot, it might be caused by boiling fuel in the float bowls. I had a similar problem. An insulating spacer between the intake manifold and the carb worked for me.
Old 05-17-2011, 10:59 AM
hoops's Avatar
Hoping for answers about starting as related to the cam and timing.
As for the reply about heat, the thermostat is 160 degrees and the intake manifold does not have heat passage that stock manifolds have so I don't think that's it.
I should also add that I have a high torque starter that works fine. In other words, the engine cranks at a good speed.
Old 05-17-2011, 01:38 PM
hoops's Avatar
Oops, I thought I forgot something, but I didn't so disregard this post.
Hard starting 29 hot rod Engine 1 08-13-2007 07:01 PM
Hard Starting Guy Hiltz Engine 1 10-07-2005 01:29 PM
5.3L Starting Hard Chevy_SS10 Engine 7 07-11-2005 06:26 PM
Hard starting classic78 Engine 3 10-23-2004 08:47 AM
Hard Starting my SBC 3Putter Engine 9 03-05-2004 11:37 AM
