hard starting - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 02-29-2012, 01:16 PM
hard starting
I have an 88 iroc engine in a 1956 chevy. It always started ok until recently. When it gets hot i have to give it a squirt of starters fluit to start it. Can someone help?
Old 03-02-2012, 06:08 PM
EagleMark's Avatar
GearHead-EFI.com
Turn key on, no start and listen for fuel pump to run for 2 seconds? You can also attach a fuel pressure gauge to the schrader valve and watch for pressure.
Has it set any codes?
Old 03-02-2012, 10:46 PM
The fuel pump does run and there are no codes..........Thanks
Old 03-03-2012, 06:27 AM
EagleMark's Avatar
GearHead-EFI.com
Well it could be a EFI issue but since it's a conversion and running well, only a hot start problem... try turning key on and let the pump run it's 2 seconds. Turn off for 10-25 seconds, turn key on let pump run 2 seconds. Rinse repeat 3 times. Then try to start. If it starts then inspect your fuel lines and see that the feed line is not getting to hot, like near exhaust.
What this will do is flush hot fuel from lines.
Old 03-03-2012, 10:05 AM
Thanks for the advice,sounds logical. I'll give it a try and let you know...Don
Recent Modern Electronic Engines posts with photos
Hard Starting hoops Engine 3 05-17-2011 01:38 PM
Hard Starting SBC zeromod Engine 6 03-24-2009 11:59 AM
5.3L Starting Hard Chevy_SS10 Engine 7 07-11-2005 06:26 PM
Hard starting classic78 Engine 3 10-23-2004 08:47 AM
Hard starting 78 monte Engine 5 02-23-2004 02:37 AM
