Hard starting engine for my 82 dodge Ram D150 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2012, 05:55 PM
My 1982 dodge Ram D150 has a carb 318 engine that is always starting hard? How do I get rid of my hard start for my truck and so it can fire up with one turn of the key not holding it for 2 minutes so it can turn over?
Old 03-11-2012, 01:17 PM
Supporter of the 4.3 liter V6
Used to have this problem with my 86 Chevy had quadrajet carb and i'd have to pump the gas pedal so the accel. pump would put fuel down into the intake. My thoughts are since carburetors aren't closed systems like FI, fuel drains back into the tank after a while and takes alot of time for the mechanical fuel pump to bring it back to the motor. See if you can install a check valve in the fuel line close to the tank to hold the fuel in the line
Old 03-11-2012, 01:29 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
I hear you on the "hard-starting Dodge" annoyance factor.
I used to imagine it saying: "No-no-no, no-no-no ... I don't want to start"
Dodge used a gear-reduction starter, and the big-blocks in particular seemed to have a very slow cranking speed. This may have resulted in longer periods of cranking to get the fuel up.
Perhaps an electric fuel pump with a regulator may be part of the solution?
Old 03-11-2012, 01:30 PM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
does the choke work
Old 03-12-2012, 08:41 PM
How stock is it?
If you don't have to worry about emissions inspection it's time to consider some ignition work, especially if you're saddled with 'Lean Burn'...
Same-Same for the carb.
I'm finishing sorting out an upgrade on a slightly later MoPar using a GM HEI module, I've been impressed so far
I started here: http://www.allpar.com/fix/electronic-ignition.html
hard starting when engine is hot Edwin Engine 6 05-11-2010 02:21 PM
Dodge Warlock Parts? ( 1980 Dodge D150 ) Silentlion_69 General Rodding Tech 6 03-24-2010 09:17 PM
What do I do with an '85 Dodge D150? Hippie Hotrodders' Lounge 10 10-08-2009 08:46 AM
hard starting when engine hot hemi joe Engine 24 05-27-2009 11:30 PM
Free 82 Dodge D150---43,272 miles Bryan59EC Hotrodders' Lounge 1 03-08-2008 06:39 PM
