Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - hard starting when engine is hot
Old 05-10-2010, 04:43 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is online now
Yada Yada Yada
The carb body, intake manifold plenum is getting too hot.
Restrict/block the exhaust heat riser passages at the intake manifold flange.
Install a wood carb heat isolation spacer.
Regulate fuel pressure to 5psi max.
fuel lines too close to the exhaust.
missing mechanical fuel pump heat isolation mounting plate/gasket.
The Following User Says Thank You to F-BIRD'88 For This Useful Post:
T Evans (12-07-2013)
