hardened seat question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2003, 06:52 PM
how goes it board?i was reading up on head work and what i read was that you only have to put hardened seats on the exhaust valve.i always assumed you put it on all valves.why is this?my cam specs are...
Duration Adv. 262in. 270ex
@.50" is 218in 224ex
lift .493in 500ex
lobe sep 110
Comp Cams Xtreme262
would the resurfaced iron seat handle this for the intake or does it need hardened seats also?
its a set of 1971 351 windsor heads and they are going on the 71 windsor.
Thanks for any help.
Blag
Old 08-01-2003, 07:44 PM
NorthStar's Avatar
The intake side doesnt get anywhere near as hot as exhaust so no hard seats required on intake valves.
Old 08-02-2003, 12:12 PM
Max Keith's Avatar
hardened valve seats
The reason for the hardened valve seats is that tetraethyl lead used as an additive used to keep the valve seats lubricated as well as up the octane. Since lead is no longer used, the seats tend to erode, hence the hardened valve seats on the exhaust. heat was also a major factor on this.
Your cam etc is not relevant to the valve seats and it will handle the higher lift etc. My recommendation is that you do a pocket porting job on the heads. This will garner you as much or more hp than does the cam you are putting in. A good pocket job is worth 35-50 hp, depending on the heads, and it effects your breathing under the cam curve greatly. I had the oportunity, to have a 302 dynoed one time, that I had built for my pickup. I was running early 351 W valves in it and an early 351 cam. .416/.416 lift 198/198 duration, with a factory cast iron 4v intake from a 289, 1 1/2 inch primary headers, and 9.5:1 comp. The second run was done after I pocket ported the heads and I gained 37 hp for my work.
Old 08-02-2003, 03:04 PM
yeah i just finished porting the heads the other day ground down the exhaust hump opened it up a little,port matched intake and smoothed out the bowls.it was a real tedious job i hope it gets me that kind of gain well thanks for helping me guys.
Blag
