hardened valve seats - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2002, 06:10 PM
stfinney's Avatar
Post hardened valve seats
How can one tell if there are hardened valve seats on a head? Also, how much does it usually cost to have them put in??
Old 11-08-2002, 02:55 AM
woodz428's Avatar
Troll Hunter
Arrow
With the valves out you should be able to see an actual ring and machine line around the seat and right under it where the head had to be cut to install them. Around here it's fairly inexpensive, I think in the neighborhood of $100-$150 parts and labor, been a while since I priced it, they charge a certain amount for the first (set up charge) and the rest are a lot cheaper.
Old 11-12-2002, 11:27 AM
bullheimer's Avatar
NEVER use credit cards!
Post
what he said, that $150 would be in addition to the $125 valve job so look at @ $250 to have it done, and you WILL have it done if you want to use them. 'less you want to add lead to your gas
