Harley generators. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2011, 11:05 AM
Harley generators.
I have a 68 HArley Sporster with magneto,no battery. My problem is the voltage regulator wore out so I replaced it with a solid state regulator. Old regulator had 5 wires new has 3. The ground was easy to fix but the 4th wire which was labeled 6I or 61 has me puzzled. I installed the regulator with the B+,Field and Armature connected and it did not work.
I may have grounded the field of the generator as I tried it.
BUt
Where would the 6i wire connect and how does the the generator get its initial excitation voltage without a battery. PS the 61 lead goes to the capacitor on the bike.
Old 06-21-2011, 05:33 PM
BUt
Whose regulator, there are several designs out there?
First the generator has to polarized. That means hooking the proper voltage source 6 volt or 12 depending on your generators volt rating. The positive lead is connected to the A terminal then the F terminal is kissed with the ground side. This provides the proper orientation of the magnetic fields.
The battery eliminator i.e. capacitor needs to be charged by the same process with the case attached to the ground terminal of the battery and the pigtail kissed to the positive. Backwards wiring for the gen and capacitor if this is a negative ground set up.
Typically on these things the battery wire is yellow and it goes to the battery terminal of the ignition switch and to the pigtail of the capacitor. The red wire is usually Armature and would connect to the generator and on to the gen light if you have one. The green wire is field and goes nowhere else. Some versions use a 4th wire black as a ground for the regulator case, if the case is metal it probably is the ground path for the electronics so it needs to bolt somewhere to the chassis a common point with the battery eliminator would be good. The eliminator needs to also connect to the ignition switch.
I've included an attachment of what this circuit should look like it's for a 4 wire regulator, the 4th simply being a ground so you can ignore it.
Bogie
Old 06-21-2011, 08:05 PM
Regulator connection
Thanks a lot old bogie,
The regulator was Drag Specialties, purchased from J&P cycles.
The 3 wires were green red and Orange.
I hope nothing is damaged but I have been trying to polarize with positive to the field and not armature.
I found an older schematic for a 65 Sporster and it showed the capacitor going to the positive lead coming from the regulator also.
I appreciate the drawing because my bike has no ignition switch and the oil and gen light are open also. I am going to try to polarize to the A, armature now and hoping it works. I have been worikng on this for 4 days now.
In your drawing the yellow wire goes to the magneto also. My bike only has a kill switch to ground to the magneto. Is it supposed to connected to the battery eliminator capacitor.
It is a litle cold blooded on starts.
Thanks again, you haVE MADE MY DAY, ESPECIALLY IF POLARIZING WORKS.
Old 06-25-2011, 04:46 PM
dklong's Avatar
rex try this site . theres a good bunch of guy's on this site. www.harleytechtalk.net
Harley Harley Wilcox Suspension - Brakes - Steering 1 10-03-2006 02:16 PM
1923 starter/generators mwskopf Hotrodders' Lounge 2 06-02-2006 02:03 PM
Harley bags Ultra Al Body - Exterior 1 02-11-2006 09:03 PM
Value of an Old Harley motorcycle RetroJoe Hotrodders' Lounge 5 07-11-2004 08:22 AM
I need a Harley fix!!!! slider in wa Hotrodders' Lounge 10 12-17-2002 07:17 PM
