harmonic balancer - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2008, 09:02 PM
bigalow's Avatar
harmonic balancer
I have a built and balanced 327 that I am putting in a project. The project requires that I use a special harmonic balancer. I cannot use the balancer that the motor was balanced with.
Are 69 327's externally balanced? Will a different balancer mess up the balance?
Old 01-08-2008, 09:38 PM
All 327s are internally balanced. Most balancers are 0 balanced, ie they are spun by themselves. Very rarely will a shop balance the whole assembly ( with the flywheel, clutch, balancer etc..) simply for just your reason, if you need to replace a single part the whole assembly must be re-balanced. You should have no issues, but on the odd chance they have mickey moused it, you should contact them and find out for sure
283 Harmonic Balancer JamesD Engine 29 03-14-2007 05:36 PM
Harmonic balancer question tornado-tech Engine 12 02-07-2006 08:00 PM
Serious problems removing harmonic balancer! spyderdude Engine 55 06-09-2005 10:01 AM
Harmonic Balancer Installation DTL504 Engine 2 06-15-2004 10:17 AM
sbc 327 vs 350 Harmonic Balancer Question Ted's37 Engine 3 07-14-2003 04:10 PM
