harmonic balancer - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2008, 06:04 PM
harmonic balancer
installed a chrome timing chain cover on a chevy small block when i used the gear puller to take it of the outer piece came off the center piece there is a rubber ring between the two now i cant figure out how to get the outer piece back on the center piece does anyone have a solution to the problem or is the balancer shot
Old 06-27-2008, 06:18 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Yep that balancer is toast, get the tool for the balancer, you will need it to reinstall a new one. Just a caution the chrome timing chain covers are notorious for leaking oil around the front of the pan, just a heads up on that.
Old 06-27-2008, 06:49 PM
v8hed's Avatar
AK427
I assume you used a regular puller (jaw type) to get the damper off. A balancer puller consists of a yoke that bolts onto the crank pulley bolt holes in the balancer. A large threaded bolt then screws into and through the yoke and pushes against the crank snout in order to pull the balancer free. Just a heads-up in case you have occasion to pull a balancer again at some point.
Cheers,
Ian.
Old 06-27-2008, 06:55 PM
SSedan64's Avatar
Pepi is right your balancer is shot. In the future don't use a gear puller on the balancer. You can go to Autozone or Advance and borrow the tool with a refundable deposit. Advance has a nice universal tool for removing & installing the balancer ($90 deposit). Autozone just has the removal tool. Balancers usually run $40-$60.
Old 06-27-2008, 10:06 PM
when i used the gear puller...
...i cant figure out how to get the outer piece back on the center piece does anyone have a solution to the problem
Yes, buy new one. Please post pics, for how not to remove.
Old 06-28-2008, 05:52 PM
thanks
well it all makes seance now. First timer . any tips on putting it back on. When I buy a new one?
Old 06-28-2008, 06:23 PM
cowbay's Avatar
The puller that you should of used is also the installer. Summit has one that I use and it costs about $70.00 See link below
http://store.summitracing.com/partde...4&autoview=sku
Old 06-29-2008, 05:37 AM
ouch expensive mistake
Old 06-29-2008, 07:38 AM
v8hed's Avatar
AK427
Here's just an install tool...
http://cgi.ebay.com/ebaymotors/_Auto...3756.m14.l1318
Only $20 and change.
Old 06-29-2008, 10:40 AM
malc's Avatar
Living At The Speed Of Life
This from Summit will remove and install your harmonic balancer.
I have one and itīs good.
Old 07-02-2008, 04:08 PM
SSedan64's Avatar
http://www.chevytech.com/2c44o6.html
http://www.chevytech.com/2c44.html
Harmonic Balancer help sexypizzaman Engine 4 02-11-2008 04:21 PM
283 Harmonic Balancer JamesD Engine 29 03-14-2007 05:36 PM
Harmonic balancer question tornado-tech Engine 12 02-07-2006 08:00 PM
Harmonic Balancer Installation DTL504 Engine 2 06-15-2004 10:17 AM
sbc 327 vs 350 Harmonic Balancer Question Ted's37 Engine 3 07-14-2003 04:10 PM
