Harmonic balancer
Ive posted last week regarding multiple starter problems with starter being kicked out even after shimming and perfect starts prior w/ no answers in sight.
My QUESTION IS THIS ... can it be that my harmonic balancer is bad and kicking out the starter? The reason i say this is i recently heard harmonics at 50 mph and none in park.2)i've virtually had to reseal the whole front end of the motor and the top. 3) my belts started squeaking and loosened up and were previously tight. 4) the timing has been off and havent touched anything... and when i look at the flexplate while running on a lift it looks like its not dead straight and has slight wobble. If these are all happening can this make a perfectly new good shimmed starter kick out and not work? ANY HELP WOULD BE GREATLY APPRECIATED ....and after replacing hundreds of high end parts and seals etc,,FRANKLY THIS CHEVELLE HAS BROKE ME!!!!!
