Harmonic balancer 305/350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2005, 03:00 PM
How can you tell the difference between a balancer for a 305 or a 350
or doesn't it make any difference? the engine is a 92 350 but I have several balancers and somehow they got intermingled they all look the same condition and sizewise. Thanks, Eric
Old 08-17-2005, 03:11 PM
DoubleVision's Avatar
In most cases the 305 used a wide hollow balancer about 6 inches tall, 350`s came with the solid 6 inch balancer or solid 8 inch balancer. All small block chevy generation 1 balancers are interchangeable anyways except the 400 small block and the vortec engines of 1996 and later.
Old 08-17-2005, 03:20 PM
The ones I have are not as I'm taking you to say solid they are for lack of a better term webbed. Three arms, so they are all right to use on the 350?
Thanks, Eric
Old 08-17-2005, 03:26 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
If they are off of SBC but not a 400 you can use them. The 400 was externally balanced and the others were internally balanced.
Old 08-17-2005, 03:54 PM
I said solid because the factory balancer is 2 pieces, the webbed section is where the bolt holes are, then there is a rubber ring and pressed on is the outer section, the outer section being solid on 350 balancers, and hollow on 305 balancers.
Old 08-18-2005, 09:59 AM
Thank you for your help, I wasn't sure and I'd rather find out from someone that knows before I drop it in. Thanks again.
Old 08-20-2005, 12:03 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Jsust because it fits and balances, doesn't mean that it will dampen the harmonics of the crankshaft. that is, keep it from fatiguing and breaking.
283 Harmonic Balancer JamesD Engine 29 03-14-2007 06:36 PM
Harmonic Balancer Installation DTL504 Engine 2 06-15-2004 11:17 AM
Removing harmonic balancer saenz5 Engine 7 05-14-2004 07:08 PM
harmonic balancer install gkev Engine 1 09-08-2003 07:51 PM
sbc 327 vs 350 Harmonic Balancer Question Ted's37 Engine 3 07-14-2003 05:10 PM
