-   -   harmonic balancer 350 chevy (http://www.hotrodders.com/forum/harmonic-balancer-350-chevy-2251.html)
jimm 03-16-2002 10:08 AM
my 350 is internal balanced,is there an advantage to having an 8" balancer v.s. 6 3/4" ? ihave put a 6500 rpm rated 6 3/4"balancer on it, motor not yet installed so easy to change now if necessary!thanks guys! jimm
Tell_Me_Y 03-16-2002 04:55 PM
[quote]Originally posted by jimm:
<strong>my 350 is internal balanced,is there an advantage to having an 8" balancer v.s. 6 3/4" ? ihave put a 6500 rpm rated 6 3/4"balancer on it, motor not yet installed so easy to change now if necessary!thanks guys! jimm</strong><hr></blockquote>
jimm the 8in may hit the timing indicator that sticks out from the timing cover beware.no
advantage otherwise that I know of.
1BAD80 03-16-2002 05:15 PM
You have to cut that tab off, very easy with a hack saw, use about 32teeth blade.
It happens on 400 motors, I had to cut mine off.
jimm 03-16-2002 05:50 PM
tell me y, 1bad 80,howdy!thanks for the input guys! i preciate it!guess i will stab it and play., thanks again,jimm
reddwarf 03-16-2002 07:42 PM
Bigger damper is supposed to be good for more RPM, but if your smaller one is good to 6500, you're probably better off with that unit than a factory job.
jimm 03-17-2002 09:54 AM
tellmey,1bad80,redwarf,thanks!i preciate it!jimm
