harmonic balancer - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2005, 12:51 AM
razorcd's Avatar
harmonic balancer
I have a problem posted a while back about an engine noise well I think i have finally found it the sleeve on the balance actually has a crack in it and could just be pulled off the crankshaft being how loose it was riding on there.
The problem being i work for advance auto parts and we can locate one for it and being every year a have looked at won't is to small. It shows 68-90 olds 350,307 all using a balancer and even 455 did also but mine is bigger then them. the shaft hole is the same but the overall size of the balancer is bigger.
I am sure this is a 350 olds without a doubt just been unable to pin point an exact year. Anyone know is they ran a bigger harmonic balancer on 350 older then 1968. I have tried summit website nothing i could find 1 junkyard going to check some more and i checked napa.
Old 10-09-2005, 09:15 AM
razorcd's Avatar
got a balancer?
I located the balancer surprisingly no one could help me in 29 views. Well onward and upward. I actually found it a dorman made part if anyone ever has this problem 68-72 olds 350 used a larger balancer then newer olds 350 well at least this is what I have found. Now the job of finding one that isn't to expensive.
Old 10-09-2005, 10:20 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Hi
I work for NAPA, but I'm not at work today ... so I can't check the Balkamp line for you.
Interestingly, I ordered one from Cross-Canada Auto Body Parts to fit my 454. It looks like decent quality and was much less than what I could get one from NAPA/Balkamp!
Here's a direct link:
http://www.crosscanadaparts.com/cgi-...mg_num=SPECHAB
If that doesn't work (cookies?)
login as guest.
scroll down to specialty parts
HAB Harmonic Balancers
283 Harmonic Balancer JamesD Engine 29 03-14-2007 05:36 PM
Serious problems removing harmonic balancer! spyderdude Engine 55 06-09-2005 10:01 AM
Harmonic Balancer Installation DTL504 Engine 2 06-15-2004 10:17 AM
Removing harmonic balancer saenz5 Engine 7 05-14-2004 06:08 PM
sbc 327 vs 350 Harmonic Balancer Question Ted's37 Engine 3 07-14-2003 04:10 PM
