Harmonic balancer Advise - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2010, 12:33 PM
whats the key for chossing a good harmonic balancer? Size/Brand/Material
its for a 355cid no more than 6500rpm solid flat tappet cam motor with lets just say 600hp, external balance. let me know if you need more info on motor.
Thanks in Advance!
Old 06-10-2010, 12:40 PM
I have a Pioneer balancer decent price and a nice piece.
Old 06-10-2010, 01:05 PM
techinspector1's Avatar
Wiki Edits: 326
Strange that you would have a 3.48" crank that is externally balanced, but hey, whatever. 600 hp probably means a blower, which would not need a damper for the crankshaft harmonics as the vibes would be dampened by the blower belt, but hey, whatever.
Damper Doctor disassembles OEM dampers (which coincidentally, have the proper bore in the hub, unlike some of the aftermarket pieces), uses new elastomeric material and presses the inertia ring back onto the hub with trememdous hydraulic pressure while properly clocking the two pieces so you can time the motor properly with a light.
http://www.damperdoctor.com/
Old 06-10-2010, 01:16 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
ATI sells a good damper. The Rattler is said to be good- I've not owed one, same w/the Fluidampr.
Yes, you might say "I need more info on motor" all right. Care to elaborate on the details??
Old 06-10-2010, 01:21 PM
my87Z's Avatar
Veteran/Firefighter-Paramedic
X2 cause unless it is like Tech 1 mentioned with forced induction then a naturally assperated 350 making 600hp is none too easy. not saying it's not possible cause it is but it's rare
Old 06-10-2010, 01:33 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
No doubt. Not even a solid roller.
A 350 w/an external balance flexplate is a common deal, the 1-piece rear main seal 350's have that, but not an externally balanced damper, so I'm wondering what's up w/that as well.
Old 06-10-2010, 02:37 PM
sorry Gentleman my apologies, it is INTERNALLY BLANCED! i just want something at a decent price that will handle the somewhat high revs and is small or bigger better? and what material is good?
its a N/A motor, i just wanted to throw 600hp out there haha
Old 06-10-2010, 03:20 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Short answers are larger is usually better up to a point, and steel is the material of choice most of the time.
HERE at "Damper Tech" is a primer on balancers. Read up on it and it will answer most of your questions, I believe.
Old 06-10-2010, 03:51 PM
hey thanks that actually did help!
Old 06-10-2010, 04:39 PM
ericnova72's Avatar
More for Less Racer
PowerBond and BHJ balancers are nice sportsman level parts, street/strip and moderate race type builds. Both are elastomer type(rubber ring) balancers. Summit Racing's line of SFI approved balancers is decent also.
305 Harmonic Balancer Torque454 Engine 15 02-19-2009 12:10 AM
What the ***** is wrong with my timing cover/ harmonic balancer!!! sexypizzaman Engine 56 10-28-2008 03:49 AM
SBC harmonic balancer install v8hed Engine 14 08-17-2008 04:10 PM
Harmonic Balancer help sexypizzaman Engine 4 02-11-2008 04:21 PM
283 Harmonic Balancer JamesD Engine 29 03-14-2007 05:36 PM
