Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Harmonic balancer install
Old 12-31-2004, 03:58 PM
bracketeer's Avatar
bracketeer bracketeer is offline
489 Lemans
Last journal entry: Street Legal
harmonic balancer
Yes there is a balancer installation tool you can buy or rent. If you are using a fluid damper use the tool or you will damage the damper. Sometimes the damper will get hot as you turn it in. It will stop and seem tight. After it cools down you may find you can get it on further. If you have a pulley alignment problem, the damper not in all the way will probably be the cause.
