Harmonic balancer issue
I JUST had the same problem. Make sure you use a grade 8 bolt. I was using the one supplied by an after market part. As soon as I switched to the grade 8 bolt, I got 60#.
Tried to redrill a crank once, which turned into a disaster. If it is not exact, the vibration will go berserk.
Good luck.
