Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Harmonic Balancer Issue
Old 10-09-2008, 03:47 PM
406 bug's Avatar
406 bug 406 bug is offline
9.82 @ 139mph
Stud it with a grade 8 . clean hole/ stud with laq. thinner; coat the hole/ thread with JB weld, insert the stud and let it cure and clamp your balancer on with a grade 8 nut. (or you could do it the correct way).
before you get too crazy, make sure you are not bottoming out your existing bolt.
