Harmonic balancer outer ring movement - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2012, 06:30 AM
Last journal entry: Still running strong
The other day I put a new timing tape on the balance an notice the outer ring had moved about an 1/8 in. towards the timing chain cover.So then I checked for TDC with a piston stop,that was right on the mark.The balance isn't a high dollar one but it was new not used an has around 6000 miles on it.Should I be worried about it?
Old 08-23-2012, 07:03 AM
I've saw several that have rotated and been off on the timing mark. However there is no way I would trust it on my engine given the cost of replacement and what happens when it comes apart.
Harmonic balancer Canuckcamaro Engine 2 03-06-2011 11:33 PM
Harmonic balancer ring 180 deg. off? 9K-sbc Engine 12 09-15-2009 08:00 PM
harmonic balancer ron72gt Engine 1 08-10-2008 09:47 AM
Harmonic Balancer help sexypizzaman Engine 4 02-11-2008 04:21 PM
Harmonic balancer 57halfton Engine 5 12-13-2006 12:09 AM
