We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 01-19-2006, 06:13 AM
tornado-tech's Avatar
tornado-tech tornado-tech is offline
Harmonic balancer question
Was setting timing on my 408 and when I set it last year, it had 18 degrees initial. When I checked it 2 nights ago, it showed 32 degrees initial. If i put it back to 18 degrees initial, it barely runs. I tried another timing light last night and it showed the same thing. I think my harmonic balancer hub slipped. The question I got if I go with a different balancer that is SFI approved, would I need to rebalance the motor since it is internally balanced and was balanced with the flexplate and balancer? The balancer now on the motor is a Pioneer 8" balancer
Old 01-19-2006, 07:01 AM
Infomaniac's Avatar
Infomaniac Infomaniac is offline
Check Out My Photo Album
Sounds like it sllipped.
You should not need to rebalance if you use the same size balancer.
Old 01-19-2006, 11:19 AM
k-star k-star is offline
balancer
striaght up swap no need to re-balance...
Make sure you check the bore size in the new balancer, many times they are undersize....
Keith
K-Star Automotive
Performance Engines
It's better to have a gun and not need it, then need a gun and not have it.
Old 01-19-2006, 01:34 PM
Oldphart's Avatar
Oldphart Oldphart is offline
Are we there yet?
I'd use a piston stop (very carefully) to find the true TDC and see if the mark lines up before I spent the money for a balancer.
Old 01-19-2006, 01:57 PM
MI2600's Avatar
MI2600 MI2600 is offline
Member# 3287
When you checked the timing this year, was the vacuum advance disconnected?
I actually know someone who did that very stupid thing.
Old 01-19-2006, 06:27 PM
Yes the vacuum advance was disconnected. I just did the piston stop check and the marks were off 14 degrees also. What if I went to 6.625" SFI balancer to replace the 8" non SFI balancer? Would that need to be rebalanced if the 6.625" balancer weighed 10.37 lbs while the existing 8" weighs 10.4 lbs?
Old 01-20-2006, 09:00 PM
xntrik's Avatar
xntrik xntrik is offline
Save a horse, Ride a Cowboy.
Overall weight has nothing to do with balance.
Old 01-20-2006, 11:12 PM
Rob Keller's Avatar
Rob Keller Rob Keller is offline
AKA:"SLOWRIDE66"take it easy!
Rob Keller's barnstar
Wiki editor
Last wiki edit: How to clean glass
Wiki Edits: 38
Balancers slip more often than most think
make sure you use the proper tools for removal & installation beating it on with BFH is not proper installation
Rob
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
Old 02-07-2006, 05:22 PM
The balancer did slip as I just finished putting on a TCI Rattler 7 1/4" balancer with a Summit timing pointer. The timing was right at 18 degrees inital as it was the when I set it last year. As far as aftermarket balancers and heating them to let them expand so they will slide on easily will void the manufacturers warranty (at least TCI's it will). It easily went on with a Moroso balancer installer and did not require a hone job due to tighter tolerances. Definitely one of the easiest balancer installs ever done.
Old 02-07-2006, 05:49 PM
Mr. Wormy Mr. Wormy is offline
older model harmonic balancers have different timing mark on them
Old 02-07-2006, 06:20 PM
Infomaniac's Avatar
I do put them in an oven at 200 degrees. The engine gets 200 degrees so it should not harm the balancer.
A lot of them need honed to proper interference fit. The ATI superdampers that I use all need honed.
Old 02-07-2006, 07:35 PM
SecGenLvr's Avatar
SecGenLvr SecGenLvr is offline
I agree...
This is probably a good idea, fixing a possible problem, may lead to more work and no fix...
Old 02-07-2006, 08:00 PM
Rob Keller's Avatar
Wiki editor
Wiki Edits: 38
I use a bolt grip puller to remove it.
I use a Harmonic balancer installer to install
the only one I know of that Does Not requires I installer is a old PONTIAC'S 350 ,400,455
R
"SlowRide66"
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Harmonic balancer question"
bad harmonic balancer? smlblcks10 Engine 5 01-31-2005 11:21 PM
Harmonic Balancer Failure Vista Cruiser Engine 10 11-23-2004 03:04 PM
what size harmonic balancer? onecoomofo Engine 14 02-28-2004 10:34 AM
283/327 harmonic balancer /damper Question 59vette Engine 5 11-16-2003 11:42 PM
Crank Pulley / Harmonic Balancer surfrat6 Engine 2 09-01-2003 05:33 PM
